Hello,
I am trying to remove my gas fireplace insert and need some guidance regarding safely shutting off gas. I have attached a pic of the valve. I believe the valve is in the the open position as it is parallel, but the 'shut' indication is making me second guess. Once I am certain it is shut, can I remove the piping that leads to the insert and cap the valve at the place indicated in the photo (outlined in square)? What type of cap would I use to do this? Would I also tape the cap threads using yellow teflon? Thanks!
