Hello all,
I have a GE GXSF30H water softener system. A couple of months ago, I stopped getting soft water out of the system. Here's what I did to fix it:
~David
- I took it apart and saw that one of the screw stems on the valve body had broken, causing the valve body to tilt forward and not allow the cam to properly engage the motor gears. I replaced the valve body and the seals between the valve body and rotor, cleaned everything and put it back together. Still no soft water.
- I ran a diagnostic to test the turbine, which was working fine.
- I checked both the switch and motor to make sure they were engaged and working, which they are.
- Since the unit is about 10 years old, I then went ahead and replaced the resin beads, along with the venturi, and then added 4 gallons of water to regenerate. Still no soft water.
- There are no clogs in the brinewell, no leaks at any of the joints with o-rings and seals, so salt bridges, and the float assembly is working perfectly. Additionally, the control board is showing no signs of malfunctioning or errors.
~David
