will66
Hi guys, I bought a house a month ago and it has a well pump under the house. I'm new to using well water and can't find the water filter...the water stopped last night in the house and by the wired shop after I used a water hose attached to a handle pump out by the wired shop...We flipped all the breakers and it would only stay on for awhile if I turned the breaker for the hot water heater off....we left both off all last night and for now everything is running fine....I'm pretty sure I have a short somewhere in the wired shop but want to see if the filter is dirty. Could the pressure of having the water hose running without using it cause too much pressure? And if it goes out again should I call a plumber OR an electrician? Thanks!
