The water pressure in the house was 90 psi and the temperature pressure relief drain was dumping hot water. They never located it and put in a new PRV in the yard. That solved the problem but I am concerned about the possibility of having 2 PRVs. I’ve heard conflicting info about this. It doesn’t help that one plumber said “you’ll know where it is when it starts leaking.”
Just dumping hot water does not necessarily mean there was a PRV. Instead there could just be a check valve at or inside of the water meter.
If there is a hidden PRV, the problem symptom I think would more likely to be a pressure drop. PRVs usually have a screen, and if that got clogged, you would get excessive pressure drop at higher flows.
Does the new PRV have a way to measure pressure in the yard box after the PRV? Also, you might note the make and model of the PRV now while the information is more readily available.
