Can you use the main stack to vent? P
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Afterworkguinness, Apr 11, 2020.
  1. Afterworkguinness
    Afterworkguinness New Member
    Apr 11, 2020
    Ontario, Canada
    I've seen diagrams where venting for a fixture is only provided by the main stack which is close to said fixture. Is this generally allowed and if so, what are the requirements to do this it correctly?
  2. hj
    The distance is somewhat immaterial other than it is limited by the same factors that limit ANY waste arm. The main stack CANNOT be used as a vent if there are ANY water using fixtures connected above it, (and it cannot be used as a drain/waste if it is venting any lower fixtures).
    [​IMG]
    Afterworkguinness likes this.
Similar Threads: main stack
Plumbing Forum, Professional & DIY Advice Do main stacks have to be vertical? Oct 20, 2020
Plumbing Forum, Professional & DIY Advice Washing machine standpipe, main stack Jul 13, 2020
Plumbing Forum, Professional & DIY Advice Vent basement floor drain into main stack Jun 8, 2020
Plumbing Forum, Professional & DIY Advice Cast drain: horizontal to vertical (main stack) May 7, 2020
Plumbing Forum, Professional & DIY Advice Washing Machine - Move From 1 1/2" Vertical Line To 3" Vertical Main Stack? Jan 16, 2020
