Can you buy replacement sections for a 3-piece shower enclosure?
Bob Boice
Seattle
Recently we repiped our home and in the shower area, the plumbers could not get to the shower valve from the back side so they had to cut a larger hole in the shower to replace the valve and fittings. To cover up the larger hole, the plumbers had to install what they call a “ smitty plate”. Some how the hole ended up off center so when they put the trim and plate on to cover up the larger hole, the trim plate was way off center and looks bad. See attached picture.
I was wondering if companies that make these 3-piece shower enclosures would sell you a separate section.
I think I have the original receipts somewhere but would have to dig around to find them. Just thought I would ask before I start digging through all my house records.
Brian94
Spring Grove, Pennsylvania
I know delta does not sell separate peieces for the people who cut holes in wrong spot for shower valve. Measure twice cut once, sounds like the company that did your repipe owes you a new surround. Then again you probably signed a waiver for liability
