coachz
Can anyone please tell me if it is possible to enable adaptive recovery on my new trane system with ux360 thermostat ? With the heat set at 66 during the night I wish the room to be at 72 at 7:00 a.m. though currently compressor is coming on at 100% at 7:00 a.m. with the strip heat. The current schedule is set at 72 at 7:00 a.m.. Outside temperature is 30°. I have a UX360 thermostat and the following condenser and air handler.
5TAMXD05AV41D TRANE HYPERION HIGH EFFICIENCY VARIABLE SPEED 3.0 TON TO 4.0 TON MULTI POSITION AIR HANDLER WITH ELECTRONIC EXPANSION VALVE AND COMFORT R MODE - 454B REFRIGERANT - EPOXY COATED ALL ALUMINUM PLATE FIN COIL - LINK COMMUNICATING OR 24 VOLT CONTROLS - BUILT-IN 1" FILTER FRAME - 10 YEAR RESIDENTIAL WARRANTY UPON REGISTRATION
5TWV8X48A1000A TRANE PREMIER XV18 TRUCOMFORT VARIABLE SPEED HEAT PUMP 4.0 TON WITH SPINFIN COIL TECHNOLOGY - R454B/A2L REFRIGERANT - CONNECTIONS 5/16 AND 3/4 - 24V CONTROLS - 12 YEAR COMPRESSOR AND 10 YEAR PARTS WARRANTY FOR RESIDENTIAL WHEN REGISTERED
