Tony VA
Hi, I'm a DIYer doing a lot of prep work myself while I wait for a plumber who's got time for my little job. I'm adding a tub in the basement of my 100-year-old house. There was a 4" cast iron floor drain that I believe was used at one point (as in 40-50+ years ago) as the drain for a basement shower. I wanted to tie my new tub drain into the last four feet of this pipe with a Fernco if possible.
When I finally cut through it, I found it about half filled with gunk. (see pics) My question is whether it's possible to clean it out and still use it. It's less than four feet from the cut to a toilet, where I'm assuming this pipe ties in, and then the stack is 2-3 feet behind that. The gunk seems too sludgy for a shopvac. Thought about using a piece of 3" PVC to try to pull out a lot of it. Any advice would be much appreciated.
