Rob Sappe
64k system (4 people) - well water
System info (not programmed)
salt lb/cuft = 6.75 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 2 ; ft3 resin = (nominal grains)/32,000
Raw hardness = 8 ; not including any compensation (PH is 5.7 and a calcite neutraliser has been added, should I compensate to say 12 or 13 on hardness as I have heard this can cause hardness to raise? iron is .056 mg/L, manganese is .128 mg/L)
People = 4 ; gallons affects reserve calc
Estimated gal/day = 240 ; 60 gal per person typical calc
Estimated days/regen = 14.13 ; Computed days ignoring reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/Upflw, Single Backwash
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 43.1 ; capacity in 1000 grains
H = 13 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 240 ; Reserve capacity gallons
DO = 28 ; Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 9 ; Brine fill minutes
FM = t0.7 ; TURBINE flow meter
system is not yet installed but just trying to get all my ducks in a row. I have been researching and trying to find specs on here as close to mine as I can.
DF = Gal ; Units
