Can No Longer Manually Start Fleck 2510 Regeneration Backwash
Biddle
Tolland, CT
I need some advice on trouble shooting my Fleck model 2510 Econominder. I can no longer manually start the backwash regeneration process. I'm guessing that means it is no longer automatically regenerating per schedule. When I turn the knob to the first stop, the motor makes a whirling sound, then stops. Nothing. When I turn it a second time to the next stop, it again makes a whirling sound, then stops. Nothing happens. Regeneration does not start. Each time I turn the knob to the next stop: whirl then stops. I've had the Fleck head for 11 years so I know how to manually start the regeneration process. Now it's not working. Can you give me some guidance what to check. I've got 2 other old Fleck 2510 heads that I can take parts from. Thanks for your help. Tedd
ditttohead
Water systems designer, R&D
Ontario California
Sounds like the piston is not moving internally but the mechanical switches are working. Take look when the motor makes noise, does the microswitch cam move? Is the piston rod moving in/out? The piston rod connects to the main piston inside the valve, the pin or pin retainer can be damaged or disconnected internally.
Biddle
Tolland, CT
Biddle
Tolland, CT
dittohead,
Thanks for your help. You asked "does micro switch cam move?". If the "micro switch cam" is also known as "drive cam" (I had to look in the manual's part list), the answer is "yes". Today, when I turned the regeneration knob, it worked and the manual back wash started. I'm pleased but surprised since it didn't work the last 5 times I tried it over the past week. I'll try it again tonight and let you know what happens. Tedd
Biddle
Tolland, CT
dittohead,
Manual regeneration is starting fine. Don't know what the problem was previous that would not allow it to start. Thanks again for your help. Tedd
