Bannerman
For soldering to be effective, will require the entire area to be totally clean to bare shiny base metal and for flux to be applied immediately after cleaning. Without the flux, the bare metal will immediate begin to oxidize and oxidation will prevent the solder from providing a pressure resistant seal. The photo above shows insufficient cleaning including the crack and surrounding piping.
While replacing the bent elbow section may appear to be a good solution, in practice, it may not be easy especially for someone with little soldering experience. Is the tubing a standard diameter so that commonly available sweat couplings will fit properly? It appears the 90• section will likely need to be replaced with an equal length of pre-bent soft copper 1/2" tubing which may require a tubing bender to prevent crushing/kinking the pipe. Also, the bracket on the left will need to be fully removed to provide access. After cutting out the cracked section, there maybe an insufficient stub protruding from the heat exchanger to solder on a coupler without interfering with the exsisting joint to the heat exchanger.
To solder the crack closed without replacing the section, will likely require cleaning the crack and surrounding metal with a wire brush attachment for a drill or Dremel tool. Depending on the crack opening width, it maybe difficult to bridge the opening without the liquified solder running through the crack into the pioe. Suggest using a piece of fully cleaned copper electrical wire sitting within the length of the crack to close the opening and to reinforce the section. Prior to soldering. With the copper wire in place, apply solder over the wire and surrounding pipe to provide a reinforced repair.
