I want to renovate my small basement bathroom. After tearing out the old metal shower insert and terrazzo shower base, I'm left with a fairly rusty, 2 inch ID cast pipe that protrudes 1-1.25 inches above the concrete floor.
I ran a hose at full blast down the pipe and had 2-3 faucets running in the house for at least 15 minutes. I watched the water flow freely underneath where the toilet used to be. The shower drain has to connect somewhere close downstream of the toilet.
Most of the shower pan/base instructions I've read and videos I've watched online, show the installation from an upstairs location with access from below or the drain is connected below the slab surface with an ABS pipe that's cut level with the floor inside of a framed out area.
I know that most likely everyone here will say, rip out the floor, replace the drain and trap, hire a licensed plumber, etc. I was hoping to keep this DIY, as the bathroom is already setup, framed out and plumbing is there. Plus this is a basement bathroom, that doesn't need to be top notch. Prior to this, it was basically a piss pot with rusted out shower walls.
I've attached some pictures for reference. Thank you all in advance for any/ all input.
