Installing a walk-in shower with separate shower head controls.
Using two Moen shower mixing valves from my local home depot, I will hook up the first mixer valve (Mixer-1) as usual: hot supply line to hot input (or side-A) and cold supply line to cold input (or side-B).
Here's my question- Instead of running the warm output of Mixer-1 up to the showerhead, I ran it to the "output" of my second mixing valve (Mixer-2). Then I hook up Showerhead-A to Mixer-2 side-A and Showerhead-B to side-B. Will Mixer-2 work to send water from one head to the other and both heads when in the middle?
I'll place them one above the other on the same wall. I'll place the temp controller (Mixer -1) on the bottom and the showerhead controller (Mixer-2) on top (installed upside down for ease of connectivity to Mixer-1).
Will it work?
Will it work?
