I agree with Reach. If you had a float switch instead of a float valve, you would not need the pressure tank/pressure switch and the well pump would not cycle. A CSV can also stop the cycling, but it would need to be installed before the tee to the tank. It can be installed in the well, at the well head, or anywhere before that tee to the pressure tank. You could also just install the Dole valve before the tee to the tank, and that would also eliminate the cycling.
Usually the well pump is just controlled by a float switch and run through a Dole valve to limit the cistern fill rate. Then the CSV/pressure tank/pressure switch are on the other pump that feeds the house.
