can I make a PEX drain with a 3/4" tee fitting, and a 3/4" Pex to CTS fitting and a 3/4" brass plug?
zx6e
NH
Can I make a PEX drain with a 3/4" tee fitting, and a 1/2" Pex to CTS fitting and a 1/2" brass plug?
I've had about the 13th leak with original Class 'M' 1980 copper and totally over it (or rather my water is). Doing complete PEX replacement and using copper crimp ring style and brass fittings only - (good riddance CU).
I need to replace this area under my water tank - (which has a shallow well pump mounted on top of it).
I am pretty sure that is a 1" outlet on the tank, so getting a 1" male threaded to 3/4" PEX crimp brass fitting.
Wondering about how to make the low point system drain (for repairs / work) to replace the old leaky one.
Was thinking either have a Tee 3/4" PEX (left) x 3/4" PEX (up) and 1/2" PEX (right) crimp fitting at the right corner there. Then crimp a short length of 1/2" PEX and then crimp to a 1/2" PEX x 1/2" female threaded NPT fitting. Then install a 1/2" brass drain plug. Something like that.
Would this be a reasonable plan? I can find nothing relevant to this query searching the internets! Thank you!!
(Middle pics shows old existing outlet / pipe under the tank which has short run to the other two pics. The wide shot is mid leak horrors but sort of shows the pump in relation to the tank with the same right to left orientation)
[/ATTACH] IMG_2873.JPG
I think people would usually use a garden hose thread faucet (boiler drain) and hook up a garden hose to actually drain the water to somewhere.
zx6e
NH
Thanks for your quick reply. Is that a better route to go?
The current brass plug is what I use to currently drain the system for work on it.
It has to be handier, and it is a good time to get rid of that galvanized reducer. I am thinking something like Everbilt VBDQTRG4EB
zx6e
NH
Thanks. I checked it out, that looks sensible.
