Maryland Plumbing Noob
Good Morning All,
I have considered this site as a very valuable resource for a number of years and for multiple issues. I really appreciate all the information. For someone who is pretty handy and who likes to do things myself, it is truly invaluable.
The title of my post basically says what I am asking. For a bit more detail, I have two sump pumps in my house in two separate basins which are located about 20' apart. Space is an issue, and I would like to pump both of them into one shared 2" line and then out of the house. I am able to pitch the 2" line a bit. At the connection of the second, downstream pump's discharge, I was thinking a "Y" fitting to connect that second discharge, with the angled leg of the Y facing up and using a 90 and 45 at the top of the second pump's discharge line in order to make it flow down into the Y. Almost like an upside down trap. Hopefully that makes sense. Both pumps have check valves near the pumps themselves. They run about once every few hours during rains. During a heavy rain, both pumps could theoretically be operating at the same time. The pumps are 1/2 hp and 3/4 hp and around 70 GPM. There would be about 45 ft of pitched run of 2" pipe from the first pump, and it would be about 25 ft. of shared from the second. Other than the 90s at the tops of the discharge (90 and 45 one the second one), there would be only one 90 and only on the first pump's section. The shared pipe would discharge outside about 6 ft away from the foundation and graded away from it.
Would this work? Does it have to be 2"? Can they share a 1.5" instead? I have seen a decent amount of information of sumps that share the same basin where they're not likely operating simultaneously, but I can't seem to find info on sumps in a row like this. Thanks in advance!
Matt
Matt
