JacksonC
My 3 year old Toto Drake has a Toto TSU53A fill valve. The valve has started to make an intermittent noise like water leaking. It makes the noise for a few minutes, then stops, then starts again. If I gently lift the float in the valve the noise will stop, but then will begin again in a few minutes. Adjusting water level screw has no effect. Is there a fix or adjustment, or should I just get a $10 Korky QuietFill Platinum fill valve from Home Depot and install? Thanks.
