I'm doing some unrelated work in a house but the homeowner stated that her booster pump hadn't worked in some time so she simply shut it off but left it hooked up. I don't see any bypass. Isn't she losing a fair amount of water pressure through the pumps stationary impellers?
I'm curious about how much pressure she may be losing & if she'd be better off cutting it out. She is not planning on replacing it.
The inlet side has a 3/4" line (as does the outlet). She has a 3/4" branch after that (reduced to 1/2") for her house and another branch T'd just off the inoperative tank as well which runs with 3/4" plastic pipe to her horse barn.
There is an old pressure gage (lots of rust in the gage) that reads 25psi.
Thanks for any help
DD
p.s. The booster pump was originallyu put in because the house is about 40' uphill from the street. She does have a jockey or booster pump at the barn (haven't seen it) to assist the water pressure there (barn is another 20' above house).
Thanks for any help
DD
