Dashersonic
I hope this isn't a repeat as I couldn't find an answer in the older threads.
I'm doing some home renovations and removed a few sections of baseboard heater. I reconnected the sections temporarily with orange PEX while I complete reno and until I reinstall baseboards to have the continuous loop because there are no shut off valve in my system to allow me to isolate or shut them off individually, only the zone control valves.
I drained, refilled, and Bled the system. The Pressure is good at 12-15lbs.
We are not using heat at this time of year.
So the problem is the boiler is not firing to supply hot water. It only runs if I turn on one of the heating zones. Went to sleep last night and woke up to a cold Boiler.
When should the circulator motor run? It's so quite I can't tell if it running when the boiler is firing, but It runs occasionally when the boiler is not firing. is this normal?
Is this normal? Any advice appreciated.
