R.S
Hi.
We bought a house which was already set up with a Buderus warmwater heating system (floors and DHW) with wood burner. All instructions are in german and I'm having a hard time finding an english version. It's hard to get a full grasp on the system when having to translate bits and pieces.
I'll ad some pics of the setup. If anyone has a similar system, can you please explain how you go about running the system?
We fill it half way up with wood, pull out the lever on the top right hand side and light it up.
When exhaust temp runs about 350 F, I push the lever in again. I turn the DHW heating element off.
I turn the DHW heating element on 140 F again, when the wood burner is finished.
Coincidentally, while writing this, it seems that there is some problem with the circulation as the temp at the top section of the buffer tank is about 150 F while the bottom section remains at 93 F even after running the wood burner for over an hour.
