Friolator
We've had a Buderus GB142/24 installed for about 7-8 years now, strictly for heat. The apartment it heats is about 1200 sq. feet. The house has older blown-in insulation, and our windows are the original double hungs with aging storm windows (that is, drafty, but will eventually be replaced).
Our DHW heater is dying and we need to replace this. I'm wondering if it makes more sense for us to simply tap into the Buderus instead of buying a new freestanding heater, since it was designed for this. My question though, is whether the model we have, which was not purchased with hot water in mind, can deal with the additional load. There are two adults and one infant in the house, with one bathroom. We're not planning on any any more kids, and while we will eventually add a second bathroom on the third floor, that will get its own tankless hot water heater so it's not a factor.
I feel like it probably won't be a big deal to do this, because despite the draftiness of the house, we keep it at 68 when we're around and 60 when we're not. The heat isn't running constantly, even in the winter, so also heating up the water for a 40 or 50 gallon tank should be ok, right?
If it would work, which of their tank models would you recommend and why? We're looking for a long lifespan here, so if the indirect tank costs a bit more than a typical hot water heater but will last longer, we're willing to spend the extra. I've been here 12 years and this is already the second hot water heater we've replaced (third if you count our rental unit downstairs!).
Also, is it possible to use the GB142 for tankless hot water? If so, how does that work? Would we need to add anything to the system to make that happen?
