Hi I have a VIQUA Impression Series water softerner from 2009.
I just got the house so I do not know the history of the softener.
Model is AWP32EB-FM https://viqua.com/product/awp32eb-fm/
I am having issues with the water being brownish for about a day after the softener regenerates.
I have tried using super iron out, but while it may have helped water still has the brownish tint if somewhat lighter.
The backwash color is also this color, I have tried running multiple backwash to get clearer water before regen but same results.
I have also left the iron out in the softener overnight (closing input valve during cycle once brine is almost all used).
The well water analysis is (before the softerner):
PH: 7.2
Total Hardness: 170 Mg/l
Iron: <0.3 Mg/l
Manganese: 0.15 Mg/l
Conductivity: 710 μm/cm
Bateria was also checked, there is none.
Current settings for the softener is:
hardness: 20 (From that calculation tools I have found mine is actually about 10 isn't it?)
days to regen: 14 (I have just changed this to 7)
Cycles are as such (Don't know how to change these):
Brine tank fill: 6 min
Brine salt dissolving: 160 min
Backwash: 8 min
Brine draw + slow rinse: 60min
Fast rinse: 4 min
Brine is all sucked in at about 20min in the cycle.
I have checked for a salt bridge the is none.
Is there anything to be done here, is this normal?
Bonus question, I'm using windsor system saver II pellets, should I use solar salt like the manual suggests?
PH: 7.2
Iron: <0.3 Mg/l
Backwash: 8 min
Fast rinse: 4 min
