Broken outdoor faucet
Christy N
Colorado Springs, CO
My outdoor faucet is broken. It leaks when not on, and water sprays from the top part (sorry don't know the terminology) when it's turned on. I don't have access to the pipes from inside my house, unless it's behind a wall or something. Any suggestions on the easiest way to fix this?? Thank you in advance :)
Sprays from here is the vacuum breaker. Sometimes the small O-ring separates under the cap. That is a thread on replacement part, if you know who makes your faucet. Normally less than a $10 part.
Water drips from here, you need a hose washer. They sell them in packs for a few dollars at any garden store. Or maybe just snug it up.
Christy N
Sprays from here is the vacuum breaker. Sometimes the small O-ring seperates under the cap. That is a thread on replacement part, if you know who makes your faucet. Normally less than a $10 part.
Ok thanks. I'll check on the vacuum breaker part.
The part where the hose connects, the problem is, it drips when there is no hose attached. I attach a hose to divert the water from dripping and sitting right up against the siding of my house :/
The end of the faucet unthreads and then the long stem will have a rubber washer at the end which can be replaced.
Most of the time, we just replace the entire faucet.
Smooky
North Carolina
The faucet closely resembles an Arrowhead Brass & Plumbing (ABP) Frost free anti-siphon 420 Series hydrant
