JonBee
At my off grid cabin I have a submersible pump (Red Lion RL12G05-2W1V , 1/2 HP, 115V, 2-wire submersible) in the lake that feeds a pressure tank for water in the cabin. The pump is on a dedicated 15A breaker in my panel. Everytime the pump is called on it successfully fills the tank almost to end of cycle but then the breaker trips right before reaching final PSI (60). Happens every time. I have done much trouble shooting but can't solve it. Any suggestions to figure this out would be much appreciated.
When I disconnect the wires that run from the pressure switch out to the pump in the lake, the breaker does not trip. So I have isolated the issue to those wires or the pump.
The pump has sat in the lake for two years now so I'm wondering if the pump is gunked up with lake silt so labouring and causing excessive current draw that trips the breaker.
I will pull the pump when the lake warms up a bit but just wondering if anyone else had this kind of problem?
Thanks!!!
System:
- Red Lion RL12G05-2W1V
- 1/2 HP, 115V, 2-wire submersible
- Installed summer 2024
- Lake water system feeding pressure tank
- Pump left in lake for two years
- Franklin Electric disconnect/control box under cabin
Symptoms:
- Pump starts and pumps water normally
- Breaker hums while pump runs
- Pressure rises from ~50 PSI to ~58 PSI
- After ~20 seconds breaker trips before cutout pressure
- Voltage drops from 119.6V idle to ~111V under load
What I checked:
- Swapped breaker with known good breaker → same problem
- Pressure switch has proper voltage
- No obvious burned terminals
- Pump does move water before trip
- Lake had heavy algae/slime last summer
- Pump has never been pulled or cleaned since install
Wiring details:
- Pump label clearly says 2-wire 115V
- Lake cable has black/yellow/red/green conductors
In Franklin box:
- black → L1
- yellow → L2
- green → ground
- red unused/capped
Franklin box appears to be acting mainly as disconnect/junction, not true 3-wire control box
Questions:
Most likely cause?
overloaded/dirty pump?
failing motor?
bad underwater splice/cable?
voltage drop?
pressure switch issue?
Would algae/slime buildup on intake or impeller cause this exact symptom: runs ~20 sec then trips?
Is it common to leave lake pumps submerged year-round for multiple seasons?
Thanks!!!
System:
Symptoms:
What I checked:
Wiring details:
In Franklin box:
- black → L1
- yellow → L2
- green → ground
- red unused/capped
Questions:
Most likely cause?
failing motor?
voltage drop?
