Seemed like when I put in the new bathtub the existing drain would work fine (same size as the old tub) but now I realize that the tailpipe is just a couple cm too short. So I was trying to remove the brass tailpipe, which is inserted into a galvanized nipple which attaches to the trap. I can't get the tailpipe loose, nor can I get that galvanized nipple to loosen up. Any advice? I tried a pipe wrench, hammering the tailpipe to loosen it up (although I don't have access to it from above so hammering it is tough). Thought about sawing it off but its so short as it is. I wouldn't even mind replacing the trap but everything is stuck! Please help!
