So I'm kicking myself because I just had this wall open and plumbers in here, but didn't think ahead on the sink plumbing. I'm putting in a vanity with drawers (IKEA), so the plumbing all needs to be tight to the wall--about 4" from the wall to the back of the drawers. I've got a 1 1/4" NPT brass stub out currently that is way too long. No fitting combo I've come up with will be <4". Even if I cut the nipple back and use a Fernco it's a bit too long. My only ideas are: 1) Cut even more off and open a little drywall enough to tighten the Fernco slightly behind the wall surface or 2) Replace the stub out with a shorter one. Would it be safe to attempt just unthreading this pipe and threading a shorter one in? It's all cast-iron plumbing the wall. I don't have any experience touching cast iron. Would you thread in PVC to get to a modern stub out? Some other idea I don't know about?
Soooo close. Maybe it'd work out?
Failed attempt at threading on an elbow. Way too long still
