ctnative
I had a new water pressure tank and all related parts installed 03/2014 by a local plumbing company. The brass manifold that connects the inlet, tank, outlet to house supply, pressure meter,drain, and pressure relief valve has started to weep water around the last two exterior threads on the house supply end. The past few months there's always a small puddle on the floor and a small drip accumulated at the bottom of the threads. If I wipe it dry it comes back within 10 minutes. I'm assuming that the brass is corroding from the inside causing the water to seep through. I'm also assuming that this is an early warning sign of an impending catastrophic failure which could be costly and that I should have it replaced sooner rather than later. Before deciding if I'm going to replace it myself or call the plumbing company back in are these types of fittings normally covered under any sort of a manufactures defect warranty? Thanks for any input.
