dougonbay
Installing a new toilet at our cabin and am stuck on installation.
The problem is that the toilet flange is not level - it's about an inch off - but the toilet itself always seemed level to us . The old wax ring had a 'long' neck and I guess that compensated for the offset. I can't get underneath to straighten it because the cabin is on a hill and the toilet is at the high end with maybe a foot clearance underneath. I really don't want to dig that out so I'd like to find a solution from the top if possible.
The diameter of the drain is 3 1/2 inches and 3 inches to the lip.
I imagine the right way is to get that flange disconnected from the floor then level it then install wax ring and toilet. In the picture it looks like screws are holding the brass to the floor but they are not. It may not be possible to move it because the flange and drainpipe may be buried in dirt. If that's the case I was thinking of adding a metal flange overlay with a spacer underneath to level it. Then because the new wax rings have a very small neck I was thinking about gluing a PVC collar onto the wax ring to make sure it extends into the drain. I'm hoping there is a better solution and really appreciate any advice.
Thanks,
Doug
Thanks,
Doug
