Matt bryniarski
I purchase a 1hp 3wire 10gpm pump from tractor supply to replace the old pump that siezed up. The old wine was 3/4hp. When I installed the new one, water barely pumped to the surface, less than a weak garden hose. The well is 80feet deep, the pump is at 71feet down and the water table is at 10 feet. I called there tec support and they said the 1hp pump was to large and should have purchased the 1/2hp or 3/4hp model, but clearly printed on the box of my pump has a chart that says it will pump 14gpm at 80ft. When I said that to the tech, they said that a dole restrictor vale or gate valve might help. Is that true?
