I should of learned from experience! I manage apartments and am a remodeling professional.
I had on separate occasions hoses burst on 2 different water heaters in the same building. Today the Braided hose in my own hose burst. That is 3 times it has happened to me. I purchased all the hoses from a very respected local supply house. The manager said he has never heard of it happening at all. I tried to convince him there may be a problem, and I now have had it happen 3 times and all the hoses came from his store.
They push the Braided hoses and today he tells me soon that may be all you can buy. It is costing too much to produce any thing but the Braided. So...
How common is this problem?
What is the best hose to use?
Mine developed a pin hole right above the fitting. As of now I have no damage, but I had years ago, a temp and pressure valve go bad. The heater is in the garage raised on a stand that sits on a platform the same height as the living room floor. When the valve went bad water got under the wall plate and ruined the engineered hardwood, but it took 2 months before it showed. Hoping it was a lot less water and that there will be no damage this time.
Thanks
Thanks
