mmnewcomb
So I think I may already know the bad news here, but I figured I would ask anyway.
I have a townhouse that I rent out. In said townhouse is a Bradford White 40gal 40k BTU water heater (Model No. MI403S6FBN4, not that that matters) that was installed approx. 10 years ago.
Yesterday my tenants came home after being away for a week to a sopping wet first floor (slab on grade with the WH in a utility closet behind the HVAC unit). The leak is coming from the white collar that the T&P valve threads into. From my limited knowledge of plumbing and water heaters, I'm assuming from what I see that the T&P valve was faulty and stuck closed, and when the pressure built too high from the tank not being used for several days the sleeve burst since the valve couldn't.
I've uploaded a picture of the T&P valve. You can see a drop of water and a small gap on the white collar surrounding the connection. I shut off the water supply to the WH, drained the tank, and then turned the water back on to see what the tank would do. When I did so, air pressure was escaping from that small space between the tank itself and the white collar. Then when enough water entered the tank water began coming out again as well.
Does this reasoning make sense? And if so, I'm guessing the whole tank has to be replaced? Any insight or advice is gladly welcomed.
