Bradford White PowerVent piping question
IPDQKWID
Minnesota
I have a Bradford White M1TW something 40gal Nat Gas Power Vent water heater. It was installed 4-5 years ago after a bad sewer back-up mucked up the burner? on the old one. It has run fine and stuff, but the other day while outside near where the vent comes out, I noticed the pipe was tweaked or twisted. It has a T on the end, and the branches on the T extend about 4-5 inches out, have screen inside. Forever I have seen the T horizontal (at least I don't remember it being otherwise) but the other day one side of the T was pointing up at around 15 degrees maybe? I twisted it back into normal place. Fresh snow, I didn't notice animal tracks or anything. Kind of let it go.
In the basement today while getting ready to tackle some plumbing and electrical out to an addition I noticed the vent pipe disconnected. It is all 3" PVC, and it was disconnected at a hub about a foot before exiting the house wall. So the straight pipe out to the T is free and hanging there. It looks to me like it wasn't ever glued. I guess my question is before I bust out the primer and cement, do I need to be worried about combustion? I don't like the sound of working with anything gas, and there's a furnace within 10 feet too. Can I prime and glue it without shutting stuff down, or should I cut power to both appliances beforehand? Thank you.
While I would prime and glue 10 ft from a flame, OSHA says 50 ft away. So I would not recommend that you would do what I would do.
Primer is category 3.
https://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=STANDARDS&p_id=10673 says
1926.152(f)(3)Category 1, 2, or 3 flammable liquids may be used only where there are no open flames or other sources of ignition within 50 feet of the operation, unless conditions warrant greater clearance.
IPDQKWID
Minnesota
Thank you. I will shut off power to both. This isn't exactly a basement in the 'basement' sense of the word. I would essentially be using fume-iferous things in a large enclosed closet. I got the pipe to slide into the hub for now, and hopefully my CO thingy is working.
Master Plumber Mark
www.weilhammerplumbing.com
Oh Pleeeease....give me a break..... you really cant be serious....
Unplug the heater if you are afraid of somehow setting something on fire
it aint gonna happen....
The next time I accidentally spill some glue or primer in a home I better call the fire
department just in case.......have the basement fumigated and get OSHA involved too..
