weigelbrood
I just installed a used 40gal propane water heater, flushed and filled. Now the prv is leaking. About 1 gal/2hrs or thereabouts. It leaks whether the water in the tank is cold or hot. I tested the valve and it does work, but seems to not close all the way.
Is there a way to remove it and clean mineral deposits away or just replace?
Its history included use a pool water heater. Could chlorine have corroded any interior parts or the valve itself?
Thanks.
Thanks.
