Jack-of-All-Trades
Our conventional hot water heater went bad. Always looking to save money wherever I can, I installed a Stiebel Eltron Tankless Electric Water Heater DHC-E 8/10 224201 240V, 7.2/9.6kW. It requires a minimum amount pressure to activate. Manufacturer recommends minimum of 30 PSI.
We have an artesian well currently with no pump. We had a submersible (several), but they, together with the control boxes, would always burn out after approximately 2 years of service. Our well technician recommended going pumpless and running strait artesian. He pulled the pump, removing at the pitless adapter. The rest of the system is still in place (old pressure tank etc.) No problems until now.
The new heater will only work for a short duration not even enough to fill a sink for hand washing dishes, then goes off. I presume due to drop in pressure. Any ideas on best way to boost pressure enough for the hot water heater to work when needed?
Thought about a booster pump... added in line right before the hot water heater, but would that not work because it is after the pressure tank?
Any help would be most appreciated.
