RobFromLI
My house has a well and a submersible pump, which leads to a pressure switch and xtrol tank in the basement, and then to a water softener / ph regulation setup, then out to the house. The pressure switch is set to 60 psi. When the washer is filling, or the sprinklers are on, etc, the pressure drops. I have thought for a long time about installing a pressure boosting pump, but my question is, in order to boost pressure, would there not have to be a greater volume of water sent out of the system, and if so will this lead to a situation at some point where the storage tank empties and the pump is putting direct suction on the well pump? My understanding of fluid dynamics / physics may be flawed here, but it seems to me if the pressure is increased to say 60 psi on all open fixtures, then more water is moving through the system, meaning more water has to come in.
