Boiler Pump
Discussion in 'Boiler Forum' started by Ki23, Mar 16, 2021.
  1. Ki23
    Ki23 New Member
    Mar 14, 2019
    Rhode Island
    Hello all,
    I had a Lockinvar Knight 085 installed last year and it's been working great. It appears as though my primary pump keeps starting/turning off for no reason. Even when the Tstats are not calling for heat, it makes a banging sound and the pump gets really hot. I have even shut the entire boiler down and the pump still makes the noise. The only way I can get it to stop is to kill the power to boiler/pump and then it obviously stops. I have a video but it won't let me post without a URL.
    Any ideas?
  2. fitter30
    fitter30 Well-Known Member
    Feb 2, 2020
    Retired service tech
    Peace valley missouri
    Model of the boiler a whn 085? There is timer for post running normally set at 60 seconds and it's adjustable also under operational info C shows if pump is calling or not.
  4. Ki23
    Ki23 New Member
    Mar 14, 2019
    Rhode Island
    That is the correct model number. I’m not familiar with operational info C. What are you referring to?
  5. Paulypfunk
    Paulypfunk In the Trades
    Feb 26, 2010
    Seattle
    Possibly an intermittent short in your wiring somewhere. Do you have high voltage and low voltage wiring run in the same conduit? You might be getting ghost signaling.
  6. fitter30
    Feb 2, 2020
Similar Threads: Boiler Pump
Boiler Forum Wilo Stratus primary boiler pump Apr 30, 2021
Boiler Forum When to Replace the Boiler - Circulating Pump Done Jan 1, 2020
Boiler Forum Boiler Circulator Pump Aquastat Nov 10, 2018
Boiler Forum Wiring Grundfos single zone relay, pump, and Rinnai E50C boiler Nov 10, 2018
Boiler Forum Boiler pump direction of flow Oct 13, 2018
