Kapara
I am in the process of converting most of my garage into a studio. 280sqft. I am in an Alliance which is similar to a Eichler. Built in the 50's. Radiant in the slab. From what I have learned these slabs require the boiler to be set at around 140-150 Fahrenheit.
My unit is a Navien Combi Boiler NCB-240 which is multi zone capable.
My issue is that if I run a second zone for the garage what will I do about the boiler temperature? I dont think I can set different temperatures for different zones unless there is a way to reduce the temperature on its way back and mixing the return and less of the new heated water?
My attached garage is a shed style roof so at the lowest point from the garage floor to the top inside uninsulated roof is 8'4" 3/4. The minimum ceiling height on a conversion is 7' 6" which means I have only 10 3/4 inch for both raising the floor and insulating the ceiling.
My idea was to use either upanor fast-trak or Schluter Bekotec but someone said I have to now be careful about water temp as since the floor would be insulated compared to my 1950's floor I would probably have to lower the temp of the boiler to prevent damage to the concrete pour over the pex. For flooring I am on the fence between Tile and vinyl planks but vinyl recommends 80 degrees and no higher.
I am in Energy Zone 2 (California) and am going to get some info tomorrow on code regulation for ceiling insulation but I think because of the code exceptions on small additions so I might not have to put R30 in the ceiling. Also does using Radiant change the R value needed in the ceilings? Will ask building dept tomorrow.
I did find info on a WATTS MixTemp 180. The Hydronic person I spoke to did not mention it so I am wondering if he is not aware of what is possible or if I am just not reading what the MixTemp does.
So what is the minimum recommended depth of the radiant tubing?
What size tubing for 280 sq ft?
liquid screed or concrete pour over tubing?
Better of using heatply or sticking with Fast-Trak/Bekotec?
I hope I provided enough info to answer any questions.
Thanks,
Mark
Thanks,
Mark
