I'm burying four terminated copper drain lines in my ceiling for future use -- three 2" horizontal drains that will serve future showers and a laundry, and one vertical 1½" drain that that will drain a sink.
All four are connected to an otherwise functioning DWV system that drain the current tub, sink & laundry.
The three 2" pipes are capped with Oatey test plugs. The vertical pipe is sealed with a copper end cap.
Being that these pipes are all capped and not yet in use, none are vented, so I imagine all four are trapping air when I do my fill & leak check from the bathtub on the floor above.
I'm wondering if I need to come up with a method to bleed the air out of the ends of the pipes? Or is enough to assume that, if there's a leak, the air will find its way out first, and the water will rise and follow?
http://www.oatey.com/Plumber/Shared/ProductGroupDetail/290/Mechanical+Test+Plug.html
