What has been affected when the psi of the bladder in the pressure tank is 10 psi lower then it should be? The pump cuts in at 42 psi and cuts out at 60 psi. The bladder has 30 psi in it. What will this do? The gauge has been checked against another and it is reading correctly.
Thank You for your help.
