The supplied hose has what appears to be a 1/2" fitting on the stop valve side. The whole thing comes with a 3/8 to 1/2 adapter (optional). The hose itself is larger than the standard 3/8 supply hose for any normal toilet.
I have not yet installed stop valves in the bathroom, just 1/2" copper stubs sticking out of the wall.
Should I continue to use the 3/8 stop valve I have (Dahl valve), or would there be any benefit to getting a 1/2" outlet stop valve? Only problem I have is it could take me a week to get one, since it would have to be ordered in my area, I have the 3/8 outlet on hand.
Also, is a 1/2 compression outlet the correct fitting, or is it likely that it should be 1/2 male pipe thread? I would think comp. is OK since that's how the 3/8 lines are installed.
