Hi. I'm installing an additional heater in my RV and need an extra propane line. I'm going to be using flexible 1/4" propane hose (20' premade). This is the area I need to tie into. You can see there are 2 brass tees coming off a galvanized tee from the black iron pipe.
My thought was to add a brass cross to replace one of the brass tees, which would need to be 3 flares to pipe on the 4th (if they make that), or else all flares then run a female flare to male pipe adapter on one of the flare ends. Otherwise, I'd need to swap out that galvanized tee with a galvanized cross, unless there's a better way to do it. Thoughts?
Thank you in advance.
