Philwgreen
In the middle of a bathroom renovation. There is a lead riser with PVC closet bend below the slab that has been cut flush with the tile floor. However, the tile guys tiled directly up to the riser leaving no room to get the brass flange on.
This is a lead riser in a concrete slab so removing the lead is not possible. What are my options?
Do I need to chip out enough tile to set the flange over the riser? If so, how do I seal the brass to the lead?
Is there another way to work with what is already there? The floor is level all around - although it does raise up (maybe 3/16 on the left side where it meets the riser.
