I'm going to be helping my son work on a duplex he is purchasing that has a bad setup for washing machine draining - BOTH apartments drain their washing machines AND laundry tubs into the sump pump basin. It smells bad and, most likely, will cause the motor on the sump pump to fail prematurely.... not to mention it shouldn't be run this way. The sump pump runs outside into the yard vs into the septic system. The whole setup is in the basement, which means it has no floor drains and the main discharge (correct term?) for the house is about 4 ft. off the basement floor as it leaves the duplex and runs into the septic tank outside.
Solution: Should I install a pump that can handle this amount of water that will send it out to the main discharge and ultimately to the septic field?
If so, what type of pump would you recommend? I need something that can handle the lint and other junk coming from a washing machine and not get clogged.
Help is greatly appreciated.
Thanks,
Antlerman
Thanks,
Antlerman
