My 3/4 hp jet pump draws water from the lake and is located about 15' above lake level. There is a 2-gallon pressure tank at the pump. This small tank was added two years ago to solve a water hammer/bounce problem. I haven't checked the air pressure in this tank lately. The pressure switch is attached to the pump. It is set for 30/50 psi cut in/out and the pressure gauge confirms this.
The larger water tank (2o gallon) is located at the cottage about 140' away on a hill. The vertical rise is about 100'. The air pressure in the tank is 28 psi. The pressure at this tank varies between 10-28 psi. This is barely satisfactory.
Before I invest in a submersible or a well, I would like to know if water pressure can be improved by moving the larger tank down to the pump house at the lake or moving the pressure switch up to the tank at the cottage.
Or are there any other options? Maybe a higher-pressure switch if available? A booster pump has already been considered and rejected.
