Best check valve type for kitchen and laundry drain?
SD-777
NJ
Looking for suggestions for a 1 1/2" check valve for a horizontal drain going to a sewer line. Not sure if any special needs because of the pressure from the washing machine pump. I currently have a flapper type valve which failed after a few years so I'm hesitant to put the same one on. I see several different types and wasn't sure which would be the best and also easy to clean. Kitchen drain runs fine without a valve, but adding the washing machine causes backflow.
This is the valve which failed: https://www.amazon.com/dp/B0064TQ2WQ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_8
Enclosed picture of the current setup.
