Hello everybody. I just finished my first tile job only to discover that I cut my hole for the tub spout about 1/4" higher than the requirement and now have a situation where the hole is bigger than can be covered by the spout. I would just get an escutcheon plate but our tub faucet is not a around shape at the back of it so it won't work. I was originally going to use threaded brass pipe for the spout but am now thinking of using the spout's copper slip ring feature and using a male npt adapter to connect to a coupling. So it would go:
Drop ear>brass>coupling>male threaded adapter>copper
and I want to bend the copper in an offset to raise the spout the 1/4" required to cover the hole. I have already checked and the spout is tall enough to cover the top and bottom of the hole if the pipe were re-centered. As long as I keep the last inch of the copper pipe true and level the slip fitting will seal and work. My question is: Is there any unforseen side effects to doing this? Will the standing water and air in the pipe corrode the drop ear faster? Will it cause a siphon effect and damage the valve? Will increased back pressure trigger the diverter? I cannot be the first person to have ever done this and I am hoping someone can weigh in. Thanks in advance.
