chrisxl
Hello,
I'm trying to install the Beckett Heat Manager on a Williamson GWA2 gas fired hot water boiler. The boiler is much oversized and the cycles are short. The Beckett Heat Manager seems easy enough for a DIYer to install and improve the short cycling a little.
I have hooked up the 120v and just wanted to confirm if it was correct to connect the 24v control wires to the damper's control wire. The Heat Manager would then be able to control the burner by controlling the damper.
Page 32 of the boiler's manual shows the damper's circuit:
https://www.williamson-thermoflo.co...d-file/GWA Boiler Manual 550142784_1212_0.pdf
Please let me know if you feel this is safe to do. Thank you.
Chris
Chris
