Hello,
I just dug a 21 foot well with a hand augur getting inspiration from some videos off you tube.
I dug around 21 deep total and hit water around around the 8 foot mark in pretty much 100% sand soil.
I copied some of the videos and used a 4 inch casement pipe and took an angle grinder to cut 10 foot well screen in that casing. In that casing I have 1 1/4 inch suction pipe with a check valve.
I then took pea gravel and filled the two inch gap between the 4 inch pipe and the sand/dirt and covers the entire 10 foot casement screen.
I thought I was going to be golden by having the pea gravel filter out the sand. However, I don't know what happened. I can't get the well to stop pumping sandy water. Ill pump sand comes and the next day after a recharge its even sandier. I assume the angle grinder cuts were to large and the pea gravel didn't have enough room (2 inches) around the casement pipe to do anything. When new water comes into the casement pipe its pushing in sand.
Now, I'm stuck and looking for some ideas.
What do you guys thing about me sliding down a sand point inside the 4 inch casement pipe? My thought is that if a sand point can have direct contact with sand it should be more then able to filter out the sand that is seeping through pea gravel and the screen cuts I made in the 4 inch casement with the angle grinder.
I have thought about the rusco sediment traps but I think they may fill up too often. (Plus I dont like how my suction line is 1 1/4 to the pump and these sediment traps are 1 or 1.5. (I dont know what's the better to choose and would love to have a matching 1 1/4 trap.
For what it's worth, this is for irrigation and I don't want to kill my pump or heads.
If anyone has an idea or can confirm my sand point idea id love to hear it. Also i have heard of a storage tank but I cant imaging how that would work as you would blow up the pump that gets the water to the storage tank.
Thanks, love the board. Im glad I found it.
