1smartass
I'm trying to avoid chiseling into an existing foundation and notching plates in a load bearing wall. Plumbing from tub will be running right under a new partition wall, which would be perfect except for the fact it's over 5 feet from where the trap will be. Tub has been purchased, and changing orientation of drain isn't an option. Following is image of area where the large tub with 2 inch drain will go, and I placed a trap approximately where it would need to be: http://i.imgur.com/PZHLoho.jpg Following is wall above where tub will go: http://i.imgur.com/SxziRSN.jpg Length of pipe in trench isn't hooked up to anything. Following is image looking down the trench: http://i.imgur.com/manokeC.jpg
Following is image of remodeling plans:http://i.imgur.com/5DVXSYX.jpg
