I'm renovating my bathroom and have already removed everything, updated the plumbing, replaced the OSB flooring with 3/4" plywood, etc..
I have the tub ready for installation and the drain/ overflow plumbing is done...on the tub but not yet connected to the trap.
You can see by the above image that there are 5 feet on the base of the tub from which the manufacturer has recommended you shim to level the tub. Given that all the walls are closed on the backside this is not the preferred method and even then I think this would be long and tenuous.
The tub has no place to put in a level support board along the back for at least a starting point and the manufacturers instructions do not specify this either. Just level with the feet as you see above.
So, given all this and a lot of research I've come up with the following plan:
1. Locate the high spot in the floor and use that to set a level around the walls to which to match up the top of the tub screwing flange.
2. Lay down some plastic over the areas where the tub feet are.
3. Put down some sand mortar mix below the tub feet
4. Put down plastic over the mortar (prevents sticking to tub feet incase I need to remove tub later on)
5. Place tub down onto mortar.
6. Adjust tub into mortar until the top level of the tub flange is level with the line made on the wall in #1 above.
7. Add a few screws to the screwing flange to hold in place.
8. Use level and a few shims along tub skirt (if needed) to ensure tub if totally level.
9. Let dry for 48 hrs.
Does this make sense? Any suggestions?
thanks,
thanks,
